weight diff
the 2500HD has a 200lb higher base curb weight for starters. Use the link to build your own and compare.
Weight link
Click on the brand select the model truck and on the left side click on model and option weights.
Thanks for the link, gave20. I thought the base weight between the two would be a bit higher going from 1500 to 2500? :cool:
not really in that case, the only difference is in the frame (going from a 6" frame to an 8" frame) you still have the 10.5" 14bolt axle, same front suspension. The transfer case is slightly larger on the HD, but that's about it.
