time for a new engine
Hi I'm new here ,my name is Lou.
My 2001 5.3 engine has 150,000 on it. It knocks badly on start-up after sitting all night, and goes away after a couple of minutes at idle. Before I spend the money on a GM replacement, has GM fixed the problem, or are the newer engines doing the same thing after a few thousand miles
You may have a carbon buildup issue. Mine has 115000 and has done it off and on since 25000.
I recommend some BG44K through the fuel system. Should help it.
I have yet to hear of a Gen 3 engine fail from what you described.
carbon buildup. do a top end clean, clean out the TB, and the IAC. then change plugs, wires, and oil. (change oil is a must! but if plugs and wires are fairly new, just leave 'em be)
drive on.
my 4.8 was knocking on cold start at 70K - did a TEC and most of it went away.
thanks for the info,where can I get this BG44K. I'll try it.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
