Texas style humor
PELICAN
  • 1 month later...
  • 4 weeks later...
Up here in Denton County (TX) I've seen the cops driving seized Hummers and F-350s...they have similar smart ass stickers pointing out where they got the trucks from....
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
