Tire suggestions: 245 or 265
I could use some quick advice. I have a 2004 2500HD 4x4 extended cab that has the stock tires (LT245/75/16). I need new tires and want to get bigger ones but keep my stock 16in aluminum wheels. Can you run 265's on there without hitting the wheel wells? My local tire guys said they didn't know if anything bigger than 245's can work, but I know I have seen guys driving around with bigger than stock tires on the aluminum wheels. Any advice? Any recommendations for tire makes/models? I found a set of Michelin LTX's in the E load range that are 265/75/16. I am thinking about going with these. Thanks for your help.
Those Michelins were the exact same tire and size that I was running on my '01 2500HD.
They looked good, rode and handled well and were one of the best (if not the best) tires that I have ever owned.
There were no clearance problems at all.
Personally I would not put anything biger on the stock (narrow) wheels than a 265/75/16. (especailly if you haul or tow heavy loads.) Alot of people are running 285's on stock wheels without any problems, but I won't go any bigger than 265's on my truck.
Have you looked at LT235/85/16 as these are as tall as the LT265/75/16 but will fit the stock aluminum rims better since they are not as wide as the LT265/75/16. Just something to look into.
I had 265 Michelins on the stock rims....Best combo so far for me.. :D
I run 265's on stock rims in the winter and they work great. There will be no clearance problems. As a matter of fact, GM authorizes the use of 265's on the truck. Your dealer can reprogram your computer to allow for the 265 tire.
Hey gang...correct me if I am wrong (and probably am) but I thought when the width of a tire is changed (say from 245 to 265s), that the speedometer does not need to be calibrated whereas the aspect ratio was changed (say from 75 to 85 series) it would have to be.
I have the stock 245 Bridgestones on my 06 and like to go to 265s.
Lee
Lee
You are. :D
Sidewall height is determined by multiplying aspect ratio (as a percentage) with the section width. I'm going to flake out here and use fake numbers to make the math easier:
tire 1: 100/50-15
tire2: 150/50-15
tire 1's sidewall height is 100(.5) = 50mm
tire 2's sidewall height is 150(0.5) = 75mm
So going from 245->265 and keeping the aspect ratio the same will still increase sidewall height, thus increasing overall tire diameter.
(Keep in mind, O.D. = ((sidewall height x2) + rim diameter) )
-Steve
Thanks for the advice so far. I got a couple suggestions about going to a taller tire, a 235/85/16 rather than the 265s. Any thoughts there?
Tire rack has a tire chart on it's website here: Tire Rack - Tire Chart
Looks like the 235/85/16 is the same diameter as the 265/75/16. The 235 will just have a narrower track, good for traction (digging in) in mud, snow, etc. (instead of floating on top).
I have a set of the Michelin LTX M/S 265/75/R16 on my truck. Handles great, never had any problems with traction in any weather so far. Truck has 18k on it, these tires were put on at 1000 miles.
The 265/75R/16's will fit your truck just fine. You are going from a 30" tire to a 31.9" tire. This will throw off your speedo and you will lose a tiny bit of power.
I installed 285/75R/16E 33.0" BFG MT's on mine, I had to trim the front air dam and crank up on the Torsion bars (just leveled out the truck with 0PSI in Air-Lift airbags in rear for pulling trailer). I have a HyperTechIII to correct speedo changes. I have 4.10 final gear and I seen a 500RPM drop at hiway speeds with the 33" tires. It did nothing for MPG, actually a bit worse. Ride was better but a lot more noisy.
If I had to do it again, I would have installed the 265's. You should see about 250-300RPM drop on the freeway. If you are pulling a trailer, keep the 30" tires or you will feel it up a hill.
Stock OEM tires weigh 38lbs.
BFG MT 285/75R/16E's weigh 50lbs. each.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
