Need a little help with a big decision
So since I am ready to upgrade my motor, I have been talking to my engine guy. He is suggesting that I replace my 305 with a HO 305 to avoid any problems. I have been talking to people that have told me I can install a 350 wit no problem. The big question is that I need new headers. What should I install on the new motor when it goes back in to the truck? I have heard good and bad about the long tube and short tube headers. If neither are a good match then should I put the stockies back on?????
Go for the 350, you wont regret it one bit. It has always been one of Chevy's best motors, and theres tons of power waiting to be found in it.
  • 3 weeks later...
Totally agree with these guys. A little known fact is that the 350 and the 305 are basically the same engine externally, with things like crank throw, piston bore, and combustion chamber cc's as the main differences. If you really want to go nuts, put the 350 block in w/the 305 heads and long tube headers. Yeah, you'll have to run 93+ octane to avoid knock, but with a high compression NA motor you'd have a screamer.
Ditto on going with the 350. I did that when the 305 LG4 block crack in my 83 Caprice wagon. They are both SBC Gen I blocks, so just about everything transfers between them. There is a version 2 of the Gen I block, 1986 and above, the change is a one piece rear main, there's conversion kits to use the 2 piece with the one piece, and still most other stuff will just bolt up as well. Then theres the Vortec heads (?? L31 ?? i think, do a search) have different intake manifold bolt pattern/placement, but again most other stuff is a direct transfer bolt on.
It's been a while, but I think it's still the Gen I block (one piece rear main) with the Vortec (?? L31 ??) heads and a nice dual-plane "carb" intake with Vortec bolt pattern, mild 224 cam making a very nice daily-driver 'once-in-a-while-stomping' engine. Not required, but do try to convert from the mechanical pump to a nice electric pump.
I've been making the assumptions that you currently are carb'd.
prolly the 70, only hard SB to get carb parts for is the LTx series theirs like one spreadbore we can find but my bro spet big bucks on his square bore and doesn't wanna give it up.
most TBI engines you can find anykind of minfold for.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
