switching teams
Well my father finally saw the light, He's owned 3 dodge trucks since 94 when they first came out with the new body style and finally after driving my chevy a few times over the last 4 months he's decided to switch teams. He's dealing with the dealer today on a Black 2000 4 door GMC Sierra SLE, with 36,000 miles. the truck has the 5.3 engine like mine with a gas strut tanneau cover, Ventshade rain quards, bug deflector (low profile ) and Lighted sun visor. Did I mention this is a stepside body. Very attractive truck, I'll take some pictures of it when he get's it home.
Glad to have your Dad's on our side. We grow stronger by the day! :exclaim:  :exclaim:  :exclaim:
Does this mean he's also gonna join in the posts? ;)  ;)
I don't think I'll be able to convince him to join the board but I'll take the switch to GMC and be happy with that. I think he will thank me everytime he fills up his truck with gas because his Reg cab Dodge with the 318 was only getting about 12 mpg. He will certainly do better then that with this truck. All interstate driving and now with the Tonneau coever he should be able to see around 15+
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
