Sparks Plugs
I was wondering if anyone has any experience with Nology Silver spark plugs.
According to there website Silver is the best electrical and thermal conductor of any metal.
Here some of there pros:
• Silver Center Electrode
• More Spark Pwer
• Deliver the Most Powerful Spark
• Increased Horsepower
• Cleaner Combustion
• Long Lasting
• Race Proven Design
• Top Quality Materials
Here is a chart of Properties of Materials
Thermal
Conductivity
W/(m•K)
Silver 407
Copper 384
Gold 310
Iridium 147
Platinum 70
Nickel 59
Electrical Conductivity
MS/m
Silver 66
Copper 57
Gold 45
Iridium 18
Platinum 10
Nickel 10
Here is the specs: for a 5.3 V8
M14x1.25 - 17.5mm reach (0.7"),
Tapered, 16mm Hex (5/8")Non-Resistor
Heat range 6-8
Model number G4YS
For a 80 dollars for 8, I was wondering if it's really worth it?
Thanks for any comments: :cheers:
the plugs appear pretty impressive, and I bet they are a step beyond the stock plugs makers put in their vehicles.
However, I must apply some skepticism towards how much of a gain you'd make out of it. Now, in a specialty racing app where you need to eek every iota of power available froma specific situation, they'd probably be just what you need. But in the environment of our engines, I really doubt that they'd do much more than the stock units. There's a reason that the stockers last 70k+ they're the right units for the application. no more, no less.
Would you see a gain from nology wires and plugs, undoubtedly. what is the gain? perhaps 2-3% (total guess). So let's do the math, and assume 5% performance gain, consistently, all around. (l33 engine)
310 HP + 10% = 325.5hp - that's pretty good
335Tq + 10% = 352 tq - wow
gas mileage 17 (epa 15-19 avg) + 5% = 18 mpg
cost of plugs + wires
282 + (8.2*8) = $353.36
OK so in theory, the plugs and wires will shave off about .2 or so in the 1/4. However, the big claim for these things, and what most of us are after is gas mileage
this gains 1 mpg, and only under ideal situations (ie - not accelerating - but let's leave that out)
now, you go from 17 t 18 mpg, a gain of 1mpg. that equates to a cost savings of 0.4 cents per gallon, with gas at an average of $3.00 a gallon. now let's take that cost into account. $350/.4c = a payback time of 87,500 miles! or, for that same 350, you can drive for free for roughy 2000 miles.
Boy, you must be using the 'new math' my father always talked about :cheers:
A 1 mpg gain over 17 mpg (to 18 mpg) is a 5.9% (1/17) gain.
5.9% of $3.00 per gallon is 17.6 cents per gallon.
or ~ 1 cent per mile (at 18 mpg).
$3.50/$0.01 = 35,000 miles
IF my math is correct.
DEWFPO
I rounded up to 1 mpg. I might have flipped the numbers around
took 17/3 rather than 3/17
either way - the breakdown of trying to drive out the value of gaining even one MPG is really bad.
not that I'm trying to bash the idea of mods at all. just the concept of justifying them via gas mileage etc.... If you wanna put stuff on. do it! thats why I live in this country. I love the fact that I have the freedom to even try this kind of thing.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
