Big fire near our place!
SoCalChris
So we were coming home from town this afternoon, watching the smoke rising from a large fire that has been burning in the wilderness area by us for the past few weeks. As we came around a hill, we noticed a small plume of smoke rising near our home. The small plume of smoke quickly spread into a large plume.
Currently, the community a few miles south of us is evacuated, and there are rumors that most of it has burned. So far, it doesn't look like the fire will spread to us, but we're not taking chances. I'll be up all night tonight watching it. Here's some pictures that I took of it earlier.
It's come a little closer, it's about 1/2 a mile from us now. We're under an evacuation standby, a shift in the wind will result in an immedeate evacuation.
The fire has grown quite a bit since yesterday. Last night it was around 300 acres, tonight it is estimated at around 13,000. It's mostly in the Gallatin National Forest, but it has already burned several houses in the community just to our south.
Chris...Don't know if you're into the fire scene or not but....try going to wildlandfire.com and signing up for the new fire post bulletin board. They have info on many new starts and big fires. It will tell you what the status on the fire is. Use it all the time down here in Cali. Even post every now and again. Let me know if you need any help or info. I work fire down in so cal and should be able to come up with something bd_hotshot@yahoo
Rich
Actually, the Big Creek fire is the one that's close to us. The South Pine fire is about 10-15 miles North of us, and is burning in a wilderness area. Since it's in a protected wilderness area, they're pretty much letting that one burn.
The conditions are getting a lot better here though. The wind has pushed the fire into an area that burned about 5 years ago, so there isn't much fuel there. Our neighborhood is the only populated area that's threatened at all, so almost all of their efforts are on preventing the fire from coming any closer to us. Also, the temperature dropped 20-30 degrees from what it was over the weekend, and it is raining today. Last night was the first time since it started that we couldn't see any flames from our house.
Things are looking good with the fire :)
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
