LUX amp wiring
Does anyone know if I bought the console wiring harness from a 04 esclade if it would plug into my 03 tahoe main harness. I'm thinking I should be able to add a LUX amp without changing pins in my harness? Any idea welcome Thanks for your input
It will connect to the Tahoe harness right under the cupholder. I put the whole Escalade console in my Suburban. Most of the amp connections will already be correct, exceptions being the Class II Serial and the rear speakers. You would also have to make some changes if you install the Escalade/Denali type 6 CD changer.
