How wide are your rims?
Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.
I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
It get absolutely nothing. No chimes, no dash lights, it won’t crank. It’s completely dead outside of the obd2 port which is throwing no codes. I’m wondering outside of a rusty ground somewhere if it could be a connection on one of the fuse blocks? I would not be surprised if water could get under the main panel under the hood on the drivers side.
Nothing comes up when I run my scanner on it. It’s hasp power but it’s not wanting to pull any data. I’ll check the ground connections they very well could have some rust I need to clean up to make the connection.
I am having a similar issue with my 2016 Denali HD. Right rear tail lights do not work. Have replaced the the bulbs / rear wiring harness / unhooked the batteries (touching the unhooked battery cables together afterwards) for 30 minutes. Would appreciate any insights
My 2021 Suburban had the cherry red tintcoat which looks like what you have.
My paint is still in great shape.
People ask me how I make is shine so much.
I do wax it several times per year.
