Rear view mirror Q?
I was playing with the buttons on my rear view mirror yesterday and found out when you hold the temp button for about 5 seconds  you can change the temp settings from Fairenheit to Celcius, I thought that was pretty cool since I didn't know that before, so I held in the comp button and waited to see what happened. after 5 seconds a little ( z ) appears and then the mirror started to count up from 8 and I stopped at 14, what Kind of settings were those??? I haven't had time to check the book and thought someone here would know?
 thanks
If you look in your owners manal there should be a map that has all of the different zones on it, find your zone and number, set the compass to it and it should be perfect.
Off Road Red is 100% correct!!!  Those numbers relate to different sections of the country and you should set yours to correspond to the area in which you live.
Wow, thanks guys I had no idea that's what I was doing. I changed it from 8 to 14 before I stopped. I'll have to get out the book and see where it's supposed to be. thanks again.
Randy
    Daniel422
    Daniel422
  • Who's Online   6 Members, 1 Anonymous, 1,143 Guests (See full list)
