New Ryobi Buffer
Okay. So today is my 22nd birthday and my father bought me a brand new Ryobi buffer. It's a 10' orbital.
I've never really used one before. Is there anything I need to know? Any tips or hints to getting the best finish? I have some swirl marks I'm gonna be removing, and I've read that a swril remove and a polish are essentially the same thing. Anyone know what the best polish is for dark applications??
Thanks a lot fellas
This is a pretty good video
http://autopia-carcare.com/mepovi.html
just download it.
As for polishing, obviously clay bar or use paintwork cleanser first. If you are just removing swirl marks and very minor scratches use a very light polish, like
http://autopia-carcare.com/fs-usmr16.html
or
http://autopia-carcare.com/son-420.html
^^^I used that stuff on my wifes last car an 03 Baja which was black and it
"erased" clear coat scratches, swirl marks and spider web scratches. It is a very light polish.
THis is good readin also
http://autopia-carcare.com/inf-paint-polish-clinic.html
Klasse is highly recommended as a sealer and Klasse glaze will give you some depth. Also to minimize swirl marks, do NOT wax in circles but in long strides
complimenting your body lines. Be liberal with the polish, personally I like to remove it by hand with a micorfiber towel and a quick detailer.
just download it.
or
So your saying apply wax by hand in a straight line vs. the random orbital? When I did that clay job I did the wax straight up and down. Seemed to work pretty good. I just used some spray wax to hold me over recently. Didn't do as well....forgot about the whole straight line.
The buffer is pretty much for polishing and sealing. I wax by hand. I've used my buffer to wax and I swear doing it by hand and going by the contours of your truck looks better
here's a good thread on it
http://www.autogeekonline.net/forum/showth...ht=wax+circular
good tip. I'm just really scared of doing it by hand. I think I'll try it both ways and see which results I like better.
Thanks a lot, you've been most helpful! I'll post pictures of results as I get them.
ok. So I'm poor. I can't really afford to buy all the products at once, so I'm getting a little at a time. I just bought a microfiber towel for drying and Mcguiar's NXT Tech Wax. It's supposed to be great stuff. I also been reading on Meguiars forum about their ScratchX, and I think thats gonna be my next purchase along with another clay kit and possibly an additional microfiber for polish or wax removal.
Upon further reading I noticed that people are using a "follow up polish" after using an abrasive product like ScratchX. Has anyone tried this? Can I sub in a sealant here? I have a little bit of Meguiar's basic polish left if not.
My next question is about bonnets. Which do I use for which product? I'm assuming to use the polish bonnet that came with the kit for the wax, and the microfiber one if I choose to remove the product with the machine.
For the ScratchX and follow up polish which bonnets do I use? I've been hearing about Cutter bonnets and such. I'm also having a little trouble finding a 10'' bonnet for my machine.
Thanks a lot fellas
Stop in Napa or anywhere where you know they carry 3M or Meguiars products, pick up some of their Swirl Remover. Both are meant to be a finishing polish to polish out swirls or "holograms" from buffing with a rotary. Really all "swirl removers" are all supposed to be used in this way. A more abrasive polish like Optimum Polish, Poorboys SSR2, or even a compound like SSR2.5, Menzerna IP, Optimum Compound, etc. are what really polish out scratches.
Using a Swril Remover by hand will remove a lot of the lighter swirl marks but in order to remove most of them (you can't ever remove every last one, and if you try to you're waisting time) and a wax like NXT that has micro-abrasives and "fillers" will hide some of the lighter ones that are left behind.
Waxing can be done in any motion you'd like, you shouldn't cause swirl marks with wax unless your finish is heavily contaiminated and/or your applicator is, rtc. Some waxes leave a better shine when applied in straight lines, some leave a better shine when applied vertically to panels. I actually favor using some liquid carnaubas in a top-to-bottom motion, comes off a Bbit easier IMO and I've noticed a slight improvement in shine over straight horizontal lines
Dolan
Dolan
Great tips.
Yea, I'm not really sure what caused the swirls. I've always done everything by hand, but I'd also always used old towels to dry it with. I'm thinking that is probably what caused it. I'll check out the 3M swirl remover and a sealer of some sort.
I'll be using random orbital, so I don't think I should have any trouble with swirls now.
Each should be no more than $15/bottle I think, it's been a while since I've boughten either.
Swirl marks can be caused during the wash process, drying, waxing/removing wax, etc. It all depends on methods and what tools you're using to do the job. You can't "prevent" swirl marks but you can slow down their appearance at best.
Use NXT before your sealant, also wait 24 hours before applying anything over NXT. I can't remember what the curing time is for NXT but 24 hours is about right for most synthetics.
I thoguht you seal then wax :uhoh:
or is the sealant doing just that.....sealing the finish product?
I never heard of that either, but I'm no expert. Most quality sealers have a
cleaner polish in them and they will rip off your wax and even itself. For example Klasse All-In-One can't be layered because it will just remove itself. Wax is generally just a 'topper'. When I sealed the black on my Silverado it was DEEP, but after I waxed it Mequires NXT Tech wax and later P21S the shine was incredibly sharp and retained the deepness. As for bonnets I purchased quite a few myself and well just used them once, I couldn't get all the wax, polish or sealer off so I had to remove by hand anyways so why bother. A nice microfiber towel and a quick detailer works just as good. I'm having problems posting tonight for some reason so I might be repeating myself. NXT tech wax is good stuff but let it completely haze over before you remove it or it will be a pain to remove it.
A sealant is just a fancy way of saying "synthetic wax", that's really all it is. Sealants need to bond to the surface so that's why they require curing times before adding a second coat. You can layer any quality sealant, they don't contain cleaners (some do but most don't) but the chemicals in them will strip off any carnauba wax you have on your truck. Synthetics last longer than carnaubas and make your paint pop more than a carnauba does making them better for light colors as well.
Like I said, NXT has micro-abrasives in it as well as fillers so NXT will strip a sealant or carnauba but you can apply anything on top of it. A good OTC combo for some people seems to be NXT followed by Meguiars #26.
ahhh that makes sense. Thanks a load man. You rock.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
