Can someone photoshop a house?
I'm wanting to see what my house would look like with a different colored vinyl siding. Can anyone change the color easily?
Thanks.
This is the color I'd like to see, Pebblestone Clay, with black shutters and all of the trim left white. It's a tan-ish color.
If possible, could the color of the shingles be changed to this, swTradWeathwd.jpg They are Iko brand Weatherwood colored shingles. They are a dark brown-ish color. The picture actually looks a good bit lighter than they do on a house.
Every time I do this kind of thing I learn better ways of doing it.
I'm using Paint Shop Pro 8, not Photoshop. Paint Shop Pro is definitely outside of the Adobe mindset, and that makes it better in my opinion. It's user interface is far better, for example. Version 8 was the last version created before Corel bought it, so it's the version I'm staying at.
That's awesome, thanks alot. I think that's what we're going to go with. The reason behind this is our house got struck by lightning memorial day weekend and burned up the attic on the second story. Nothing else inside was burnt, but there was tons of water damage. It's in the process right now of being gutted and repaired. It had/has painted cedar siding but this is a huge help in our decision of which vinyl siding to use during the rebuild.
Which tools do you use in paint sho pro to do that? I have an older version, but don't know how to do stuff like that.
Thanks again. :cheers:
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
