Saturn Sky
Guest chevydeerhunter
I saw one of these yesterday and it looked really nice. It's pretty much the same as the Pontiac Solstice, but I think it's better looking. I may have to stop by and take one out for a drive.
General Information
Year
Manufacturer
Model
Trim
Body Type
Base MSRP 2007
Saturn
Sky
Red Line
Roadster
Dimensions
Curb Weight
Weight Distribution
Length
Height
Width
Front Headroom
Front Legroom
Wheelbase
Wheel Rim Size 2,990 lbs.
52-48
161.1"
50.1"
71.4"
38.4"
42.7"
95.1"
18"
Engine
Type
Drivetrain
Valvetrain
Cylinder Configuration
Displacement
Horsepower(HP)
Torque(LBs-FT.)
Redline 2.0 Liter Turbocharged Gas
Front Engine / RWD
16-Valve DOHC
In-line 4
1,998 cc
260 @ 5300 RPM
260 @ 5300 RPM
6300 RPM
Transmission
Gear Type
1st Gear Ratio
2nd Gear
3rd
4th
5th
Final Drive
Reverse 5-Speed Manual
3.75:1
2.26:1
1.37:1
1:1
0.73:1
3.73:1
3.67:1
Performance
0-60 mph
0-100 mph
1/4 Mile
Top Speed
Gas Mileage 5.5 s
13.9 s @ 100 mph
21 MPG City / 30 MPG Highway
Yeah I saw one a couple of weeks ago and it looked pretty good. Hope there is a market for them, we have a Pontiac dealership about two minutes away from my hosue and a couple of Solstice's have been sitting there all summer.
When I posted this, it was 2 am and now I've gotten a chance to look at the specs. I didn't know it was a rear wheel drive with 230 horses and 230 pound feet of torque. At 2990lbs. and turbocharged, that thing should fly. I wish they would build an awd version.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
