1/2 & 3/4 ton frame ?
can anyone tell me the differences between the 1/2 ton and 3/4 ton frames on 02 4x4s and if i can swap the engine crossmember from a 3/4ton into a 1/2 ton?
Why do you want to use a 3/4 ton cross member? Are you planning on putting an oddball engine in your truck. GM uses different front frame sections depending on the Engine option being used. You have to be more specific in what you are planning on doing and then maybe we can offer some advice.
from what i can see on my 02 4x4 and the 03 2x4 there not much of a diff between the frames so i want to do a 8.1 swap in to one of them i think the 2x4 would be a fun little truck to drive
If you don't get any replies on this forum you can also post this question in the performance section of FSC. There are alot of guys on there that do the type of swap you are enquiring about and you will open up this question to a lot more readers by posting on both forums.
