1/2 2wd steering
has any one have any problems with the steering system on the 1/2 2wd trucks? my buddy had to have his replaced and i know some other person who has had it replaced twice. bty my truck is a 2005 GMC serria 1500 2wd.
The pitman arm on my 96 is a wear part so it will need to be replaced sooner or later. Also, with ten years on it the steering gear/box is leaking a bit and has started to show a bit of play, so I will replace that eventually. Also, tie rod ends and ball doints can/do go after a while and do require replacement.
Mike
