Brake Light trouble
I'm over 1,000 miles from home and the only brake light that works on my '05 crew cab is the center light.
My blinkers work...my tail lights work. The brake fuse is ok. I'm at a loss. Any help would be appreciated!
Guest chevydeerhunter
If it's under warranty, take it back to the dealer.
Are you towing a trailer, and what is the condition of your trailer plug under the bumper?
The last time I towed a trailer was in June. The truck is very clean. A friend of mine has a meter...we'll try to see if I have a hot trailer socket.
If it were the brake sensor above the peddle...wouldn't the high mounted fail to work???
if the 3rd brake lite works when stepping on the pedal, it ain the brake light switch on the pedal.
if turn signal bulbs and brake light bulbs share a common filament and the turn signals work but the brake lights dont, it is quite possible that the turn signal switch is bad.
the turn signal switch is the voltage divider in that kind of set up, all the brake light electricity.
did ya try stepping on the brakes and wigglin the trun lever around and see if the brake lites flicker, that will let you know if its the turn signal switch
  • 3 months later...
hey what did you find? im having the same problem?
I agree with Mr. Kick, the turn signal switch is probably T.U. My sister's '01 Blazer had the same problem. The dealer replaced the turn signal switch/lever and that was it.
After about $250 and 2 stays in the shop...my lights are fixed. There was a short in the left wiring harness. I got a break in the price of the harnes as they had used the right half on another vehicle.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
