Parts store pricing WOW
Just got back from both AutoZone and Kragen...Fram Air Filter CA8755A was $22.99 at both stores..went to Wal-Mart and same item was $12.49...ALMOST half price...I'm sure Wal-Mart is not using this item for a lost price leader...and I'll bet the same item at the dealer will be about $49.95...so who is gauging and who is selling low...I'll bet Wal-Mart is still making at least 30% or it won't stock an item. Even places like some of the BIG home improvement store won't carry an item unless they can make at least 60% on an item...
So shop around people...keep your money in your pockets and not the pockets of the CEO's getting 400 MILLION dollar retirement buyouts.
You still use fram??  :nopity:
What's wrong with Fram air filters? :confused: I know why their oil filters are disliked, but what's up with their air filters?
Meh.. if they'll cheapen up the oil filters like they have, why wouldn't they cheapen up.. everything else as well?
/Used to think fram was the best, too.
As for why it was so cheap at Wal-Mart, remember that they buy pretty much everything in HUGE quantities to get the best deal they can, or negotiate deals to get things cheap from the manufacturer. They also buy stuff at auctions and anyplace else they can get it cheap. Their financial people are some of the BEST at beating up their suppliers. Unfortunately, their suppliers need all the business they can get, so they take the abuse. The only company I know of that's better at beating up suppliers is GM.
Also, WalMart often encourages their suppliers to sell them poorer quality items than they are selling to their other vendors, so they can sell them cheaper.
For example, Levi Jeans that are sold at WalMart aren't the same Levi's that you would buy at Sears. They are an offbrand that Levis buys, and relabels as genuine Levis, so they can sell them to WalMart for less.
Here's some articles about it...
http://www.fastcompany.com/magazine/102/open_snapper.html
http://www.fastcompany.com/online/77/walmart.html
http://www.cio.com/archive/071503/levis.html
That story makes me not buy critical items like filters and oil at WalMart, I simply don't trust the things that they're selling there. It especially makes me wonder about that when the 5 quart jugs of Mobil1 that WalMart sells aren't available anywhere else.
As far as cheap Mobile1, Costco sells it by the case, for slightly higher than WalMart does.
I honestly don't know if the Mobil1 that WalMart sells is any diffent than the Mobil1 sold by other stores. I'm just speculating, based on what they do with other items, and that you can't buy Mobil1 in the same style container that WalMart sells anywhere else.
For all I know, it could be the exact same stuff, I just don't really feel like chancing it over a few dollars.
:nopity:
Do you really think Exxon/Mobil (a company that could buy wal-mart with petty cash) is going to risk their reputation just to sell to Wal-Mart ???
Their Oil (Exxon/Mobil) HAS to meet specifications from API and several other labs and NOT Wal-Mart...
Wal-Mart makes money by cheap labor...do you think they encourages the cows to make a lower grade milk ???
FYI 5qt JUGS of Mobil 1 can be bought at almost any Parts store...yes even in SoCal where you are.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
