New to this site- Just bought a Silverado
2000 Silverado, 54k miles, 4WD, Z71, loaded, leather (which needs repair) matching hard cover, tow package. $11k
I bought it Friday, did the MAC cold air intake yesterday. Not sure if it made a BIG difference but it sure sounds good! :gmc:
Zane, how ya doin?
That sounds like a pretty good deal! Looks like somebody cranked the bejeebers out of those torsion bars :cheers:
Welcome to the boards :gmc:
I am pretty new to the whole truck thing, what do you mean?
Normally, the front end sits pretty low on the Z71's (a pretty common complaint for most of us). A lot of folks crank the set bolts on their torsion bar adjustment keys to raise the front up a bit either for looks, or to clear slightly larger than stock tires. It takes one socket and about 2 minutes to do, tops. The height of your front end seems quite a bit higher than stock...It probably rides pretty stiff unless the front shocks have been replaced with longer than stock ones (or they've been shimmed down a bit). Of course..."Stiff ride" means different things to different people. If you're happy with it, I wouldn't worry about it.
Although, I could be wrong and it's just the angle of the pics, or just the fact that I ate a bunch of paint chips yesterday. :gmc:
Although, I could be wrong and it's just the angle of the pics, or just the fact that I ate a bunch of paint chips yesterday. :cheers:
Thanks. Not sure what if any mods were done by the original owner, I bought it from the second owner who didn't do much other than drive it. It does ride fairly stiff, but my other car is a BMW 540i so maybe I am a little biased :gmc: It is going to need tires in the future, it has a pretty good vibration and the previous owner said he tried to get it balanced out but couldn't.
I am going to need to do some research on what tires to go to, and I am considered wheels too so I want to make sure I like what I get.
What flavor paint chips? :cheers:
I'm pretty vanilla. Sherwin Williams "Snowflake Interior White" is my favorite.
There's tons of info here on T-bars and tires.
Lead based paint is my favorite, did I ever mention I was 4' 7" and my IQ was 65?
Nice truck and it sounds like you got a good deal on it.
you got yourself a KILLER deal!!! Looks just like my Z71 though mine is two tone, tan on the lower half and has a few little dents and dings and scratches all over (it IS a truck afterall) :gmc:
You did get a great deal. My friend bought the same truck as that, same year, same price except his had 97,000 miles and is silver.
I dunno, a lot of the rounded front end bodystyle Ive seen have sit exactly that height . I think they started the Rake front ends in 02 or 03
heres a 99 GMC
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
