2006 Z71
Sunoco
2006 Z71 4" Rancho lift
33 12.5 17 Nitto Mud Grapplers
MKW 25 17x8
Mccullough hid low beams
Rancho adjustable shocks
Rancho steering stabalizer
NFAB nerf bars
that is sick
this is why :chevrolet:s will ALWAYS dominate the truck world
what brand tire shine do you use? and does it last?
I just cleaned it up is why it appears shinny, but I use the armor all. I used the extreme tire shine this time, it does seem to last longer.
Actually the truck does fit in the garage and I can barely squeak into a parking garage with about 3 inches to spare. I was thinking of adding a 3inch body lift and 35's but then I'd loose practicality so it will most likely they way it is now.
Thanks for the complements!
You're from Texas too? I can tell by the small part of your front license plate where it isn't smudged out.
That is an AWESOME looking truck!!
Sick truck man! Did you install the lift yourself? I was leaning toward the Rancho 4" for my truck and I was just wondering how smooth it went.
I had 4wheelparts do the install, I did not feel comfortable doing it myself.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
