Trans temp gauge
My truck has the 4L80E tranny and I was wondering what temps people are seeing on their gauges...
The highest I've seen is 160* and normally it is 140-150*.  I put about 15 miles on the other night when it was cool outside (mid 40's) and it never got over 110*.
The 6.0L comes up to temp about twice as fast as my old 5.3L.  That'll be nice in the winter time, along with the heated seats too...
Here in FL, I'm seeing 160-190. The higher one when towing my trailer. Lowest is 140 when I leave the house before the sun is up.
Brian
I see 140 to 150 after I have been driving for 15  to 20 miles. I was surprised at how long it takes for it to come up to operating temp.
My owners manual indicates the normal trans temp
range to be from 160 to 200. I just returned from a
trip to the 4 corners region of the SW while towing
an 8000 lb trailer with the truck at about 6500 lbs and
my guage stayed within that range with the usual
towing temp being 175. A hard climb would get it to about 190/195 and a long downhill run would drop it to
about 150. All these temps are approx, I figure the
smallest increments on the guage to be about 12 degrees.
hburton,
First of all welcome to the forum. Second I have a 1/2 ton with a 3/4 to cluster so I am not running the same weight as the 3/4 tons. Besides I have not taken my truck past 15 miles on the longest trip since I had the new cluster installed so my tranny may not be getting up to the operating temp.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
