jdsmooth Posted November 18, 2006 Posted November 18, 2006 OK - I have waited long enough. I want to install the amp and sub I had in my 03 Tahoe into my 07 Denali. I had previously used a PAC adapter for my 2003, but with no new adapter available I went searching for the subwoofer wires under the console. I figure that I should be able to tap a high-level signal from the subwoofer speaker cables and get the bass frequencies I want to run to the amp. I have done this with Tahoes in the past and it worked like a charm. I removed the cup holder assembly (just lift and it will snap out from the center and back) and found the sub enclosure. There is a 4 wire harness that looks like it is going to it. It is cliped to the passenger side of the opening. For some reason I didn't want to disconnect it and find out that I was wrong or end up with an airbag in my face. The wire colors were red, green, white/red and white/green. My guess is signal +/-, power and ground. Has anyone tried this or does anyone have the wiring diagrm for the console? Have we talked about this before?
jdsmooth Posted November 22, 2006 Author Posted November 22, 2006 Anyone have any insight? I can't be the only one not thrilled with the stock gmt 900 setup...
