Wester 87/91 dual tune
I have the 87/91 wester tune on my 01 pickup. I have had it in for only a week. I was wondering who is happy with this tune and is difference in using a higher octane gas worth it? Also what kind of increases of gas mileage are you seeing?
I have the same tune in my 05 and to be honest i dont feel any performance gains. I have run both octanes through it and the only thing i feel is different is the down shift points and firmness. I recently swapped back in the factory pcm and it feels maybe a little stronger from a stop. I want to try pcm for less next time. When the truck was new it would burn the tires pretty good and now it wont. Only have about 17,000 miles on it.
I love my tune. It will take a couple of weeks for the tune to be completely learned. I have noticed a huge difference in throttle response and power gains. The gas mileage part I am not sure of since I put 35" tires on at the same time.
I have the 89/91 dual tune and love it. Perked my truck up quite a bit and also eliminating most of the torque management made a HUGE difference in the way the truck performs.
I feel the Westers tune I have is the best bang for the buck out there. If yours feels slower or not drastically improved, I would call back and talk with them. Did you remove most of your TM?
I have an 87-89 tune from Westers. Had an 87-91 and it was awesome on the highway but the shift firmness when it was warmed up was too much in slow traffic. Since gas was too expensive, went with an 87-89 on the retune and it has been pretty good but not quite as good as the 91. Also softened up the shifts so that probably made a difference. I think most of the gain now is from the removal of torque management.
Really notice the added pep in the low to mid-range rpms. Not that much at WOT except that it will run to 5600 (where I asked for it to be set) instead of shifting at 5200.
Lyndon is pretty good with customer service. Email him and he will get back to you the next day. It should be quite a noticeable difference so if you don't feel it, contact him.
I have noticed mine has run a little bit better. I am trying the different octanes to see what kind of results I get. But I have noticed it still shifts a lot on hills, where as when I had the wait4me tune it wouldn't shift that much at all. So I dont know what to think. Also my Wester's rep. said the 4.8 wont respond much to tuning as the 5.3 or the 6.0 would.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
