BigRok Posted November 30, 2006 Posted November 30, 2006 I have a 2006 Denali, I am wanting to connect the rear video output (from the panasonic DVD player) up to the front nav screen. Does anyone know what wires to tap into at the DVD player to run an RCA to the front? The front end is covered off with the PAC VCI-GM2
5strinz Posted November 30, 2006 Posted November 30, 2006 I have a 2006 Denali, I am wanting to connect the rear video output (from the panasonic DVD player) up to the front nav screen. Does anyone know what wires to tap into at the DVD player to run an RCA to the front? The front end is covered off with the PAC VCI-GM2 <{POST_SNAPBACK}> There is no video IN on the HU. The HU video is RBG and the rear screen is composite video, so you need to add an adapter to see video on the nav HU. TVandnavtogo and Navtv are 2 companies that make the composite to rbg converter in a plug and play configuration. Both converters also have inputs for a back up cam to be added to the HU. dave
BigRok Posted November 30, 2006 Author Posted November 30, 2006 I have a 2006 Denali, I am wanting to connect the rear video output (from the panasonic DVD player) up to the front nav screen. Does anyone know what wires to tap into at the DVD player to run an RCA to the front? The front end is covered off with the PAC VCI-GM2 <{POST_SNAPBACK}> There is no video IN on the HU. The HU video is RBG and the rear screen is composite video, so you need to add an adapter to see video on the nav HU. TVandnavtogo and Navtv are 2 companies that make the composite to rbg converter in a plug and play configuration. Both converters also have inputs for a back up cam to be added to the HU. dave <{POST_SNAPBACK}> Not worried about interface to the head unit, just need to pick up the wires from the DVD player in the back......
