FAILURE TO START
HaertBeat
A'M FROM KUWAIT, ARABIAN GULF
I HAVE 2003 SILVERADO ,2500HD,8.1, ALLY TRAN ,ONE DAY I TRIED TO START IT
STARTER CRANKING BUT NO IGNITION
BATTERIES ARE NEW
TRIED TO START 10 TIMES BUT IT WONT START
SO I CALLED THE BREAKDOWN TRUCK AND SHIPPED MY CHEVY TO AC DELCO DEALER
WHEN DOWNLOADED ,THE TECHNICIAN GAVE IT A START AND IT STARTED RIGHT AWAY
WE CHECKED THE FUEL PUMP ,WORKING WELL ,FUEL PRESS 55PSI AND HOLDING
I AM PUZZLED PLEASE HELP ME , THIS COULD HAPPEN 200KM IN THE MIDDLE OF NO WHERE
Crank sensor failure is very common on that engine. I can almost guarantee you that this is your problem.
This sensor is located behind the driver's side cylinder head, in the block. They often break off when trying to remove it.
IS THIS FAULT COMES AND GOES....i.e INTERMITTENT & HOW TO CHECK IT .
I WENT TO A FRIEND OF MINE WHO IS WORKING IN ELECTRICAL WORKSHOP AND USUALLY DOING GM CARS, HIS DIAGNOSIS WAS:
A LOOSE CONNECTION OF THE FUEL PUMP AS IT HAS TWO CONNECTIONS , ONE INSIDE THE FUEL TANK THE OTHER OUTSIDE IT.
THANX
:confused:
  • 1 month later...
