Heat problems!
I am having a problem with the heat in my 99 Sierra NBS w/ 153,000 miles. There was a night about two weeks ago where it got down to about 5 degrees F. I started my truck up and turned the dial all the way to the right so it was all heat and the dial to the far right to defrost and lower vent. I let the truck warm up for about ten minutes and when I got inside it was still freezing, also it was only comming out of the dash and not the floor vents. I adjusted the dial so it was for the vents in your face and the floor vents and nothing happened, it stayed in defrost and it was still very cool temperature wise.
I said screw it and took off! That was the only time that the selector did NOT work properly, to this day the selectors work, BUT...... The heat just isn't as strong as far as temperature goes. It seems like it's blowing in the low 60's at the most. Before it would roast you right out of the cab, and now it seems I have to drive an hour just to get it so I can take my jacket off.
So my question is.... Could it be the Climate Control Module (Where you select the fan speed, temperature and which vents) or does it sound like it is more likely a thermostat or a heater core issue??? Like I said earlier the other problem does not exist anymore it's just the fact that it doesn't get as hot as it used to.
Any thoughts or suggestions would be appreciated! :cool:
The two combined issues would seem to point more towards the controller.
First does the engine come up to normal operating temperature?
If so I doubt it is the thermostat.
Second, once the engine is warm are both the hoses coming out of the heater core warm/hot? If only one is the heater core is completely blocked, if both are warm hot it could be partially blocked.
Third can you hear the air mix door moving in the dash when you cycle the temperature control? It might be pretty quiet so just be cause you can't hear it doesn't mean it isn't moving. The motor that controls it migh have become disconnected from the door istself as well.
I would first try flushing the heater core, then replaceing the thermostat. Simply because those are the two cheapest possibilities. Less than 10$ The controller is over a 100$
You could also take it to a dealer and they can check all the electronics too. Making sure the controller is "adjusting the temperature as indicated on the switch, and should be able to veridfy air mix door position, according to switch...
I think the three likely culprits are the clogged heater core, or controller.
Thanks man, I appreciate the quick reply!
I'll have to look into that. I won't be able to check it over until I get home this weekend.
The truck does come up to temp and I just had my coolant flushed around 5,000 miles ago. But I'm really curious to check the inlet and outlet hoses on the heater core to see how hot they are... Say that one is hot and the other is cool (So it's completely blocked), does any lube place do this and you say it's cheap the get the heater core flushed??
Just out of curiousity, how do I know if the heater core is crap?
Also, check the heater control valve first. If the engine comes up to normal operating temperature, and the heater valve does not work, then the hot coolant will not flow into the heater core. So no or weak heat. If the heater valve is good, and heater core is good, then the temperature controller is your problem.
If you had a thermostat sticking open due to some debgris in the cooling system, then the temperature gauge would indicate low temperature at all times and heater would not put out sufficient heat.
It's not the thermostat so...
To flush the core, pull the two hoses going though the firewall to the core loose, so that two tubes stick out of the fire wall. Use a water hose and run as much water as you so desire in each tube going in to the fire wall. That will flush any debris out of the core.
The two signs of heater core failure is coolant smell in the cab and or foggy windows. Means a leaking heater core. Heat on only one side, weak heat, no heat. Can mean a clogged up heater core.
Okay, thanks guys. I'll look into everything when I get the truck back this weekend. I'll let you know what I find out. Thanks again!
:cool::P
    250.3k
    user087
    user087
  • Who's Online   5 Members, 0 Anonymous, 946 Guests (See full list)
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
