94 1500 5.7 with spark knock.
dreamingmuscle
Besides switching to a higher octane gas. How do I find out what is causing it and get rid of it?
New plugs wires and cap were installed this summer and I adjusted the timing to 0 BTDC with the little brown wire unplugged.
What else can I be missing?
Glen
Glen
Hook up your timing light and as the engine is running tap on the block with a hammer. The timing should retard. If it doesn't,your anti-knock sensor is bad. Even if your sensor is good, you may still have some spark knock with lower octane gas. My truck has always needed 91+ octane to completely get rid of spark knock.
