GMT 900 Availability
I love the looks of the new truck and have the itch to trade in my '04 GMC Sierra SLT Z71 extended cab. But - the availability of the new trucks seems very thin. I don't think I've seen more than two at a time at any of the local dealerships. Is it just my area or is inventory really that thin ? I don't even see many of the '07 Classic trucks either. Hope GM truck sales in '07 don't actually decline due to inventory availability. I'd like '07 to be the year that Chevrolet truck sales edge out Ford!
Going home from my parents house yesterday a dealer had about 10 at least on the lot. Some have 2-3 and some have a ton. I guess it depends on how many the dealer ordered
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
