Extended Cab Side Window
My side window was busted and now needs to be replaced. I was wondering if anyone knew the part number for the driver's side, side window for a 1998 K1500. I am having trouble locating one.
Thanks,
Nate
I've had good luck with Rockauto.com and GMPartsDirect.com - in both cases, if you can't find the PN you need online, just drop them an email.
Thanks,
Nate
If it's the pop out window on the Extended cab section, make sure to specify whether or not you have the darker tinted privacy glass. If it's drivers door glass, then it doesn't matter - they're all the same.
Thanks,
Nate
LMC truck has them in their catalog. Do a web search for them.
