Removing Seats
jhoff8487
I've got a 2006 Regular Cab 1500 Silverado W/T and want to replace the center seat back with one that will fold down and act as an arm rest as well. I found one from Llebroc and to install it I must remove the passenger seat. Is there anything I have to do to remove the seats other than just unbolt them? I don't have power seats or anything of that nature as it's a stripped work truck but are the nuts contained or do I have to crawl underneath the truck or what? I haven't really looked at it as my truck is at my girlfriend's house which is 60 miles away but I'm curious as to what you'd reccomend. Is it as simple as removing 4 bolts and picking it up or is it something more than that? Do I have to pull my air bag fuse or discconect the battery? I'm still pretty new at this stuff. Thanks.
Unplug the electrical connector and remove the 4 bolts. No need to disconnect the battery, although it always a precaution while disconnecting anything. The bolts have a inverted torx. Not sure of the size.
The bolts will have a funny look to them, just use a 6 point 11mm and 15mm deep socket to get them off. That is what I used to remove my seats a couple weeks ago. I don't remember which size was for the front and back, but they are different sizes. In fact the fronts are nuts with the backs being bolts.
Have a nice day.
Bill
the nuts require a torx socket but you can use a 12 point deep socket 11mm and 15mm.
I tried to find a torx socket that would fit, but I could not find it anywhere. As you say, those metric sockets work just fine. I have a seat raising bracket kit which I am planning to install. This will raise the seats about 2 inches,
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
