NEW TO FORUM
HI & yes I thought I would help HERE also as I have helped for 2 years in August with the tracking of your "babies" on TDP as you wonder where they are at or when they are going to get "HOME!"   Any questions, contact me at [email protected] I look forward to helping in my OWN LITTLE WAY??!!  Howard  :D   :D  :D
Thanks for offering the help Howard.I know some members that are going to find it useful in the future.
I've seen you post on PUTC before and know that you have helped a lot of people.We really appreciate you being here.  :D
Hi Howard,
Anybody that has any complaints about their truck, Howard has all the answers !!!!!!
Nooooo Just kidding :D
Good to see you on this board Howard.
Mike
WELCOME!! Glad to see you hear bud!  :D
Hey pontiac,glad to see you here.I still remember when I got the train # from ya and tracked my truck from the plant all the way here  :D I still cant beleive I talked the guy into letting me drive it off the railcar !!! They didnt have an idea of how I got all the info :D  :D  thanks pontiac!
:D   HI MIKE & I hope we can get some people involved enough to have a truck reunion this year!!!
HI PULLING POWER & YES I use you as an example once in a while while working with these people & their trucks.  You got 'BIG ONES" when it comes to asking to drive the "BABY" off the r/r/car!!!  Howard :D  :D  :D
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
