8100 oil pan
I need to replace a cracked oil pan on my 2002 2500HD extended cab and was wondering anyone had any suggestions on the easiest way to do this. Thanks.
I have yet to do this on a 8100 HD but usually a truck can be done with the engine raised up as high as possible. Loosen the transmission mount as much as possible. Remove the engine mount through bolts and jack or hoist it up until you've hit the firewall or streched hoses and wires to the limit then use 2x4 blocks placed between the the engine mount halfs to chock it in place. If it still won't come out undo the transmission mount and jack the trans up to the floor pan. It should come out now by dropping the rear below the trans bell then sliding bacwards until it clears the engine cross member.
Keep a good eye on hoses and wires when raising the engine, disconnect them if necessary but go slowly and check often.
Vernon
I’ve not done an 8.1 yet but the 6.0 is not bad. I replaced the oil pan on my 4x4 6.0 in about 4 hours on a rack. As I recall, here is the procedure.
Remove the front drive shaft.
Remove the O2 sensor.
Remove the right side exhaust pipe from the manifold and the support bracket near transmission. This will let the Y pipe drop enough to remove the inspection cover.
Remove the upper differential mounting bolt and loosen the lower, remove the 2 nuts on the left securing the half shaft. This will let the differential rotate forward.
There was a wiring loom mounted on the front of the pan remove the bolt on the right side and slide the bracket to the right
The only thing left is to remove the pan. On the 6.0 I didn't have to lift the engine.
You might want to put a small amount of gasket maker on the rear corners of the pan when you back with it. Good luck!!
Well, looks like the oil pan may be easier than I thought. I have to replace the front differential because of a broken mounting tab so I should be able to get the oil pan off while I have the front end out with no problems!! Thanks for the help.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
