Oil pressure switch location
doverarjim
Could anyone tell me the location of the oil pressure switch on a 95 Chev 305??? Thanks in advance for your help. :banghead:
The oil pressure switch is located behind and below the distributor with a black plastic electrical connector attached to it. The best and easiest way to replace it is to pull the distributor which makes it quite easy. Hard as hell if you dont pull the distributor. Voice of experience talking here. Good luck.
