Looking at a 2007 3/4 have a few questions
I am looking at trading my 2005- 1/2 ton Extended in for a Crew. I want to get the crew and move to the new Eaton locker rear-end and the 100,000 mile warranty and maybe move to a few more options.
I am looking at the left over 2007 Classic 1/2 tons, but I am hearing alot of buzz about the deals they are throwing for the 2007 Classic body 3/4 tons.
I don't really have to have a 3/4 but it would be nice for the occasional trailer pull to Colorado.
What kind of MPG could I expect out of a 2007 6.0? Do they come with the fuel managment system?
The 07 Classic 3/4 tons do not come with active fuel management. That's the new platform. I traded in my 03 1500 for a 2007 Classic HD with the 6.0L and 4.10's. You can get some great deals on them now! The 6.0L is a pig on gas and I will tell you that up front. Best I've gotten on the highway was 14mpg so far but I only have 900mi on it. I work from home 3 days a week so I'm not that concerned about mileage and my wife takes the MARC train to work everyday so if I need to drive a good distance for work I take her Explorer. I must admit that now I have the HD I like it much better over my 03 1500.
It depends on if gas mileage is really that important to you. If it is than I would stick with a 1500. I was considering a new 07 1500, but my wife said I should just get the 2500 HD cause that's what I wanted back in 03 but couldn't afford it and now we could. Gas wasn't an issue with me and if it was I wouldn't have considered a 3/4ton anyway. At the end of the day just buy what makes you happy and you can't go wrong :banghead: I did and don't regret it one bit!! :)
The 2007 Classic 2500HD do not come with the Displacement on Demand(old Name). My 2006 2500HD with the 6.0L gets about 12-13 city but the motor only has about 2000 miles on it. I have gotten up to 17mpg on the HWY, on my 2001 2500Suburban.
I would say if you can do it, get a 2500HD its better to have a little overkill vs not being able to do it when the need arises. Granted its only about 5-10% that most people will ever need the capablities of a HD, but when that need arises a 1500 just can't compete, and do it with a good margine of safety.
I also got my 2006 2500HD in Oct of 2006 for $21,080.00 out the door so yes the deals are out there! Good luck.
mpg in the low teens. But throw a tune on the 6.0 and it will walk the dog.
FWIW I would stick with the 5.3 if it met my needs, but I tow a fifth wheel, so...
DT
I average around 14.5 combined city and highway with 3.73 gears in mine.
Your going to get lots better fuel economy with the 5.3 in the 1/2 ton and very comfortable ride.
DEWFPO
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 800 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
