my son ran in 4wd on dry pavement... now what?
:crackup:
I passed my 1996 4wd Tahoe to my son, a new driver. He comes home from work today and says the truck is handling funny. I back her out of the driveway and it's tough to turn. I check.... yep, it's in 4wd.
He drove it about 5 miles, complete with turns (about a dozen maybe?) and parking. (sigh).
What whould I be looking for in terms of damage? If he hurt the truck, how obvious would it be? Listening carefully, it seems to make extra noises sometimes when turning - some clunking sounds. Have we bent something up front in the steering area?
How do I know if the transfer case is damaged - will it just go to pieces at 50mph somewhere down the road?
I've run in a straightline in 2wd, 4hi & 4lo and no pieces fell out.....
The good news is he knew something was wrong. The bad news? Well, I'm waiting for your replies....
Thanks for you help.
Shouldn't have hurt it, I know some people who driven it in 4wd on accident for longer than that with no damage.
Normally running them for only 5 miles won't hurt anything. My dad accidently ran his '94 3500 dually in 4HI for about 20 miles once before he realized it, and nothing was ever damaged. As far as bending something in the steering area, if there is something bent you would probably feel it in the steering but I doubt anything was bent.
Well, my dad accidentally ran his '02 2500 hd in 4wd for about 10 miles at about 70...a few days later the front end locked up...thats how we found out it was messed up. It locked up, brought us to a stop, then drove normally in 2wd...4wd didnt work anymore. Luckily it was under warrenty, so they fixed it. still, it sucked. But that is the easiest way to find out if something is messed up. What they said happened was all the oil burned out and it was running dry, things got hot and broke.
Having driven my ZR2 on miles of dry roads by accident and on purpose... It shouldn't have really hurt it, I don't believe at least. :crackup:
btw: welcome to the site!
Nothing is going to happen to it.
I have a question, how come people get so worked up about running in 4wd? I put my trucks in 4wd at the beginning on winter and they stay there untill all the snow is gone, ice, snow, or bare tar, it works fine for many miles every year. In fact, I would bet I put way more miles on the truck in 4wd than not. Late october to about mid april on average for my 4wd season.
Not true. You have moving parts in there. Moving parts create friction. Friction creates heat. Heat destroys things when it gets too high for too long. Running in 4wd at high speeds for long periods of time creates unneeded stress and heat, causing parts to break. You heat up the oil in there enough and it will either find a way out or do damage in some way or another. Its like a transmission, you get it too hot and it will break.
Your exactly right, but what was your point? How are my front end components receiving unneeded stress? If the gear ratio and the tire size the same than where is the stress? Everything should be in sync.
From what I understand the biggest problem w/ running in 4wd is turning, when you turn your inside wheels turn slower than the outside, and the front wheels dont have a differential to account for this, so either your tires will slip on the pavement or something mechanical will slip (ie break). If your lucky enough to have your tires slip then all your doing is putting excessive wear on your transfer case... They just arnt designed to be run on dry pavement.
When it's snowing, I put my truck in 4wd and drive to work. I take the highway, drive about 50mph for about 10 miles. Someone told me I shouldn't go over 35 in 4wd or I could ruin my truck. I didn't believe them, but what's the truth? Thanks.
Well, here are my two cents (which are worth almost nothing in other currencies):
I NEVER drive mine in 4WD except when I'm off road. Call me a sissy, but when you make sharp turns in 4W hi, that front axle just whines and spools up even at low speeds (10 - 15 mph). I tried to turn in mine once and it just locked up. I.e., I'm in 4W hi, I start turning (doing about 5 mph) and all of a sudden, I come to a complete halt. I push the gas, and i get a Ford truck response: nothing. Put it back in 2WD, and (surprise) linear motion once again.
I doubt this guy tore anything up because afterall, why did we buy the best truck on the market? Because it's bulletproof. If you did tear it up, it would probably lock up on you or be leaking somewhere. But I must say, I don't use mine except of road, and I always drive slowly and avoid sharp turns. i paid too much for the Z71 decals to tear up my ride.
Your right, it will bind up on bare pavement, but in the winter time, when you find bare tar at intersections, the tar is covered with sand so the sand lets your tires slip. Even then, a tire is going to take the abuse over the driveline components because the tires will give and wear easier than the metal components, and on top of that, a turn at a intersection isn't even that sharp of a turn. Do a u turn on bare tar and then you might hop around and bind up real bad, and if you do that on purpose you need to be beat with a noodle.
I understand if the vehicle is in 4X4 all the time; more parts are in use and more wear and tear occur, plus the heat issue. What about the AWD vehicles like the SS? Do they use a different transfer case or different internals? And what about the front end components? What is the difference in design that they can be full time but a 4X4 is part time?
Im done hijacking.
as long as the axel ratio and tire size are the same. your fine. I drove mine 240 miles at 75 to 80 pulling our 33 ft fiver in 4 hi. duhhhh
had to add a little fluid. that was a few tears ago. no probs so far..
Exactly. I don't understand why people think running in 4wd is bad? Do they think the gear ratios are different? It dosen't make any sense, I can see the tight turning stand point but besides that its tom foolery.
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
