G1500 Savana with the 4.3L ?
Hi all!
Do you people think that a G1500 Savana (not extended, and most likely cargo) with the 4.3L will move around smoothly or is it underpowered of an engine for that monster ?
I don't really need outstanding offroad capabilities, I'm thinking about a Savana only for the cargo size and the pickup-like ground clearance.
Thanks for your advices!
:loser:
If you aren't going to load it comepletly full of weight and don't need to be a rocket then it will probably be fine. The most that I have towed with a 4.3 is a 18' fishing boat. That was with a '95 blazer, it wasn't a speed demon but it did the job.
i have a 4.3 in a 00 silverado stepside reg cab ... it is plenty powerful for me. for 2000 dollars i could have gotten the 4.8l with crew cab. In hindsight. i think that would have been the better choice. but hey, i shouldnt complain too much. i like my truck. and i have an extra 2000 bucks in my pocket
How the hell did you pull an 18ft boat with only a 4.3? We had trouble pulling our 19ft with our 5.3L
QUOTE(S-Ten @ Feb 22 2007, 06:11 PM) *
It's an Aluminum Fishing boat with tiller steering for a motor, it is not like a fiberglass ski boat that is really heavy. And like I said, it wasn't a speed demon. I have towed it with my current truck as well which is much better but still not fast, the key is just not to be in any hurry I guess.
Thanks guys!
Yeah, I won't be loading the thing too much (food for like 5-6 days, maybe a week along with standard camping gear) and a 14' foot aluminum fishing boat ontop of it.
And is there an issue checklist for the Vortex 4.3L? I heard many things about injection problems, etc.
let me add something here guys. I use trucks as work trucks. I used to have a sonoma with a 2.2l 120hp engine. It was about as underpowered as you can possibly go. People said i couldnt pull anything with it but I bulled a 14ft fishing boat every weekend in the summer. i occasionally pulled 1500lbs of rock in the bed (4500 on a trailer once). and had no problems.
ive had my 4.3l silverado since october so the most ive pulled was 2 skids worth off frozen pizzas (doing a favour for a company). i dont kow how much that weighed but it was heavy and it pulled it fine. with a tranny cooler, i think you could pull 5000lbs easily with this truck. and 5000 lbs is a lot of weight. a 16ft fishing boat weighs less than 2000 lbs bare. with all your cargo you be pulling a max of 3000-4000lbs .. the 4.3 could take that easy. yes its only 200hp... put the power with way down low. so its designed to be a hauler.
That is the reason that I like the 4.3, as well as my current 350. :driving:
You're right about the Sonoma. I used to have a 96 S10 2.2L for 4 years. That thing was a dog. But it really did pull alot. It was one of those "Lead Sleds" type trucks...where even though it was slow, it would still tow a house down.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
