Confused about leveling kits
I have a 2006 Silverado Z-71 crew cab. I've decided to install a leveling kit to bring the front end up even with the rear.
The problem is I don't know which one to buy. I have seen some inexpensive ones for $65 and I saw one made by Ready Lift for $229. I don't mind spending the extra money, but I want to make sure I'm not wasting it. I have no knowledge in this area, please lend some advice.
Make sure the one for $65 is for 4wd. 4wd needs torsion bar keys and 2wd uses coil spring spacers.
I used the Ford keys on my 03' Escalade, they worked good, your ride will be slightly more harsh, but not bad ay all
Remember they are just called the "ford" keys which are
only the green ones that come on the 1500 GM models. I also
note posts from a few guys that paid big $$ for a leveling
kit got a GM key with the GM name and/or part number
ground off..........................
Want new t-bar keys? Go to any GM dealer less than $30 bucks!
The green keys won't do anything for him. He has a 1500, so he already has green keys. He needs ford keys, from a ford dealer, which are different from the ones that come on a 1500 chevy.
Yep, what he said...
thanks guys
I picked up the ford keys from the dealer today. The price was about $42 for the pair.
I'll be sure to post before & after pics
thanks guys
Can you post up the ford p/n? Thanks!
I dont want to hijack this thread but, ive heard that adjusting your torsion bars without adding new keys can decrease ride quality and cause parts to wear out quicker. Now whats the difference between adjusting the torsion bars and adding new keys, i mean, the fron of the truck is still coming up and angles are still changing? Any input?
Def post pics and ride qualtiy changes after you put the ford keys in. I have been contemplating buying a leveling kit for some time, but if the ford keys work just as good why not save 200 bones.
As promised here are some pics. I reaised the front exactly 2" using the ford keys. The ride is fine, the OEM shocks are fine. Turned out well :)
Before
After
I bought the Ford keys at the local dealer for $42. I used a Craftsman 2 arm, 7 ton gear puller. It took me about 40 min, and that was taking my time. I have never done this before, but if you know how to turn a wrench you can do it. Just be sure to use at least a 7 ton puller. I don't think the 5 ton puller would have worked. No, I did not add blacks to the rear. I just wanted to level the front.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
