WT OLM help!
So I have an 07 classic work truck. First oil change was at 1000 miles and I did the OLM reset.
How the hell do I check how much oil life is left? This is pissing me off becuase the miles are getting up there and I decided to stick with the OLM on this truck.
I just want to know wether 50% is left or what.
I just dont want to little message to come on CHANGE OIL, becuase for me having the time to get an oil change takes like 4-5 weeks to find the time (you work 70 hour weeks + 2 hour commute each way).
Thanks!
Huh, good question. I don't know if there is a way to check it if you don't have the steering wheel controls. Anything in the manual?
If you dont have full DIC the only way to check is with a Tech 2 or equivelent. Depending on your driving habits the OLM will go on anywhere between 4000 & 8000 mi. GM recommends and oil change within 600 mi of OLM coming on.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
