I have a 1992 gmc sierra extended cab and the front end wont engage in 4 wheel drive any suggestions on how to fix without a lot of expense
Most likely it's the actuator that engages the axle. They are heat activated in that era and are notorious for failing. Replacement is an electric version I believe.
  • 4 weeks later...
  • 4 weeks later...
Thanks,
I am going to upgrade my 97 with the 98 actuator. Almost got stuck a couple times waiting for it to engage.
check if the 4X4 fuse is blown. On the inside fuse panel.
I had the same problem on my bros 93 and that fixed it.
