Effect of larger tires on mpg
according an online calculator @ 4lo.com
Based on 4.10 rear
245 dia = 30.5" w=9.6
265 dia = 31.6" w=10.4" effective rear axle drops to 3.96
285 dia = 32.8" w=11.2" effective rear axle drops to 3.8
Am I understanding this correctly,
if I increase the tire size which will reduce the axle ratio my mpg will increase?
Or will the increase in tire weight and width negate it?
I tow monthly ( long like 1200 miles) 6,000 trailer with 2,000 in the cargo bed
my 2500 8.1 gets about 9.5 mpg at 68mpg.
I'm trying to increase that mpg a little, I only have 9,000 miles on it so far with Mobil 1, otherwise stock.
I think it kinda depends on how big you go. I went from 245/75-16s to 265/75-16s on my '03 and didn't really notice any difference. A larger increase in tire size would add considerable rolling resistance and would negate the effective axle ratio decrease.
Your MPG should increase, the engine has enough torque that it wont be struggling whatsoever to turn the added weight/diameter. Therefore the adjusted final drive ratio decrease would mean less RPMs at speed. The actual results would vary depending on the tire, if you got something really knobby there will be considerable more rolling friction which will hurt mpg.
Plus, if you dont correct the speedo with a tune, your truck will gain value every mile you drive (at least over the stock tires it will), your odometer will be quite a bit less than actual after awhile.
What you want for mpg increase...talking tires. Is a tall, thin tire. The height changes your ratio but if you don't increase your width you don't add friction. Look how thin the tires are on the little economy cars.
On my '01 6.0L I put 265/75/16 Michelin LTX M/S and I saw no difference in MPG's over stock size.
On my '05 Dmax I put the more aggressive Bridgestone REVO's 265/75/16 and lost a little MPG's over stock size tires.
I went from michelin 245's to BFG AT 285's. I actually lost close to 1 MPG on my 6.0 with 4:10's. I don't really care though, it looks wayyy better.
Exactly
When calculating mileage, you also have to take into acount that with a larger tire your speedo will be off. I switched from 265's to 285's and according to discount tire's website, when my speedo says 65 I'm actually going 67.26. Difference would be even more (about 4.5mph) switching from 245 to 285. I just got my new tires yeterday so I'll post back later my mpg, but I'm not expecting much either way.
I went from a 245 to a 265 and mine went down 1mpg or so. I notice the engine revs a little higher than before.
Huh??? How could your engine RPM increase when you increased your tire size? It would have to decrease.
The mileage decrease I understand, and is normal.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
