Confused On 2/4 Drop
so the plan is to do a 2/4 drop with Boss 301 20" wheels. tire rack says the correct tire size for that is 285/50/20. Are 285s going to be too wide?
I guess there are a couple different types of drops. I'm wandering what the best way to drop is. I see there are spindle drops, arent there spring drops too? Do i really need to change out the spindles?
Is the only thing needed for the rear some new shackles? :confused:
im thinking about just doing the eibach pro kit. 2/ 3.25 rear or something
thanks
  • 3 weeks later...
go with 275/45/r20's. 285 will stick out from under the fender, depending on your wheels offset. i had my truck dropped 2/4 and put 275/55/r20's on it and thought if i hit a bump i'll drive my front tires into the fender so i put it to just 2 inch shackles in the rear. wished i had went with the 45's. lol, jd
like blkshadow said....all depends on backspacing...with the right backspacing you could probably fit 315's in there
check what it is on the 301's and look around at what others have installed.
Is the only thing needed for the rear some new shackles? :D
thanks
Tire rack doesn't take into account that you are lowering your truck.
most of the tire dealers look at what came factory on your truck and try to stay within 3% of the original tire size. they also look at the load limits of the tire to that specified for the truck. they told me the 275/45/r20 did not meet load limits for my truck but it is within 3% of original tire size. i went with the 275/55/r20 and been kicking myself ever since. with lowering your truck i would go with the 275/45/r20 and you shoudn't have any issues. lol, jd
yeah really...if you're lowering it I don't think your gonna be cartin' around a whole pile of stuff in the box, so what does the load limits really matter.
and you could pretty much put any tire size you want on there if you have a programmer to change what your speedo sees.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
