i have a 89 s10 work truck so i only have the fule gauge and the speedo. i have come across full gauges didital and analog. the analog has everything even a tach and came out of a 88 blazer 4x4 with a 5 speed i have a 5 speed as well. the digital cluster came out of a 89 sonoma 4x4 with an auto. will these work with just simple plug and play pr is there more to it
  • 7 months later...
Chris.
I just recently swapped out the clusters in my '01 S10, it is a straight plug and play...that being said a couple of caveats...make sure the engine and transmissions are a match for your truck, also make note of your odometer reading as the mileage is stored in the cluster not the ECM (like Ford), I went from 72,500 to 43,600 in about a 1/2 hour. You need to keep track so you can honestly disclose the mileage when you sell (Ohio has some stiff penalties, it is a felony) also in case your mileage jumps up :P .
Good Luck.
Mike.
