This One Is Just Wierd...
Sitting here waiting for a response, figured I'd throw this out there. While driving, I hear a scattered ticking noise in the defroster / dashboard. When I hit 50, this noise goes insane. When I removed the airbox for the new cold air, the bottom of the airbox was filler with CORN! Underneath the filter! I'm assuming that is the noise, but do not know how to get to it without (or how to) disassembling the dashboard. Could that corn have made it through, or could it be something else?
Corn? Well that is weird.
Are you the original owner? Perhaps someone has planned a practical joke on you?
No, I bought the truck used. No idea how the corn got in there, the previous owner did something out of the norm. The rodent stash was pretty funny, but this is my daily driver, and I live in the city, and keep it clean enough to have the old lady compare her to the truck. (I'd go with the truck, but we gots the kids, ha!)
You mean corn in the engine intake?
How would THAT make it to the dash? It goes straight into the throttle body...So it appears you have two problems, one of which appears to be kinda corny.
When I bought my '02, there were acorns in my airbox...Not sure how stuff like that makes it in there, but it's not all that uncommon.
Unless you went through a corn storm, z85violator is correct, you've got a rodent, or had one. You haven't noticed any red splatter under the hood have you? I can't even imagine how corn would get into your air box any other way.
Maybe the previous owner thought it was a Flex Fuel ride but just didn't understand?
Daddy.
I've got a similar situation with a red squirrel stashing pine cones inside the tubes that connect the frame rails on my 02 Sierra. I agree with the other guys, must be some type of rodent.
Heh, the last time I changed the air filter on my truck, there was about half a pack worth of Keebler elf cookies in there. Now I don't feel so strange.
Daddy.
yeah, flex fuel the old school way. lmao
Has Orville Redenbocker been hanging around your house? Seriously, you have a squirrel or mice problem. Happens a lot.
This has to be the most entertaining post I've done. My original question was how to get the dash out to remove the corn whipping around in there, without destroying the dash. Maybe I'll pull the filter again and put some walnuts in there. It'll be harder for them to make it to the dash.
I'd try to rig a slim piece of hose to a shop vac and see if you can suck the kernels out. It's a lot easier and faster than dismantling the dash
d**n mice. Put some moth balls in a ziplock back and put them in a secure place in your engine compartment. Ive heard that can keep them away.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
