1988 Chevy Silverado Truck Parts
Hey everyone, I'm a new member today, but I bought a 1988 Chevy Silverado last year, but it was beat up kind of, just needs some parts, and it will be ready to go, which I do have the parts to get it running, but I still need some more little parts and stuff. here is what I need:
-rear view mirror
-parking brake cables
-alternator mounting brackets
-ac system
-both right and left side mirrors
-fuel level sender
-float
-4 wheel drive emissions system
-stainless braided fuel lines
-driver side inside door handle
-big bottom radiator hose-the one on the passenger side
Well this is all for now, I'll post more when I come accross more parts I need. So if you have any of these parts, especially the fuel level sender and the float, and the radiator hose, please let me know, I really need those now.
go here.
www.LMCtruck.com and get the free magazine mailed to you
it has all GM pickups parts 88-98. Theyre priced dammn good too!
I went onto lmctruck.com and requested a free catalog for my truck. I still need a lot of parts to get my truck running, and I might have to sell the motor, because its not the right motor that is in it, I don't think, I might just see if I can trade it to a salvage yard for the right motor that is supposed to be in my truck, because the motor that is supposed to be in this truck is a 350 and this motor is not a 350, so I need to find out what year it is, so I can figure out if this motor is out of a corvette like the person I bought it from told me. He told me this motor was out of a corvette, and I didn't know what to think at first, I looked at it, and looked at other motors in trucks like mine, same years, and they looked the same, but the ones at the salvage yards had 350 in them, how can i tell, the oil filters on the motors were bigger than the oil filter I got on mine.
It could be a 305 (5.0L). I know a lot of people with that motor around here. We call them the "boat anchors" cause they all go bad easy. Not that it doesn't have any grunt. My buddy's 77 K-10 on 40s used to do pretty well with that motor, and he abused the hell out of it. He put just about every kind of oil you can think of in that motor and it still ran.
yea, I found out what motor this is. I got a 327 motor in my truck. It was taken out of a Corvette. I dunno why, but this motor was beat on hard by the last owner, but the truck quit running because for one, he kept running it low on gas and running it out of gas, and the aircleaner he had on the motor, it was hitting the coil connection wires and one wire on one of the connectors has been like stripped, but it got hot and melted the plastic around the wires and the wire came disconnected somehow, it was like cut or something, and that is why the truck quit running. and the last owner was too stupid to try and figure this out and fix it, but its his loss. I bought the truck for $500, paid $200 cash and traded a ford probe for $300 for partial trade for the truck. And I just bought a brand new alternator for this motor and its not the right alternator. So now I need to get an alternator for a 327 gm motor. I dunno what year it is, but I'll try and figure this out
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
