Pimp My Ride, 65 Impala With A Dmax
Black02Silverado
Man, they did that Impala up nice. The DMax fits nicely. They ran it off 100% biodiesel too. HMMMM now to look at what I can do to my 65 Impala SS. Anyone else see the show. I was just on at 1PM EST on MTV.
800 HP and 1400lbsft torque. 0-60 in 3.5 seconds. I wonder how much it cost to do all that? Goes to show diesels can work the technology is there. It even gets 25mpg. If Pimp My Ride can do it then there is no reason the big 3 can't.
That car was BADASS!! I want one. At least they didn't do that all stupid, Like with a fish tank for instruments or disco ball under the hood. I cant believe that tank smoked a Lambo. :thumbs:
Guest chevydeerhunter
That car was BADASS!! I want one. At least they didn't do that all stupid, Like with a fish tank for instruments or disco ball under the hood. I cant believe that tank smoked a Lambo. :chevy:
Yeah, but the interior was way too pimp for me. The paint was smokin'.
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
