Black Bowtie Emblem
Does anyone make a black overlay for the bowtie emblems? I would really like one for my HD, it would look pretty good with my paintjob, but I have had no luck finding any. Would it be worth getting another emblem for a project and painting it?
Painting would be one easy way. Another would be to use black contact paper.
Probably wouldn't have much trouble finding another emblem at a salvage yard.
Thanks for the replies. I have been checking ebay constantly but haven't found one for a large Silverado emblem. The black contact paper idea sounds pretty interesting. If I paint it my plan is to sand it lightly and prime & spray paint black a couple times then clear it a couple times, hopefully it will work out and be nice & shiny.
I painted my factory bowtie a while back. I lightly sanded it to allow for a better bond, ran a couple coats of automotive spray primer, several coats of black and several coats of clear coat. It didn't come out as smooth as I would have liked, but it looked good. The only problem I had with it is that anytime I took a small piece of road debris, it would chip or leave a divot in the paint. I finally got tired of re-sanding and painting that I finally bought a billet bowtie and have been running that ever since.
oh so painting isn't really the best method? i'll give it a try for kicks though, i'm not gonna use my trucks original though incase I mess up lol. I could probably get one of those billet emblems powder coated black too.
I think I am going to try smoking it heavilly them clearing it, rather than painting, we shall see how it goes..
Well I have been searching for a while too but finally found a spot that has overlays. Here is the link, just got mine in black.
WebXtremes
Go and Get em!!
  • 4 weeks later...
I thought I would drop by this old thread & post my new blacked out emblem :flag:
I removed it and sprayed it with 9 layers of vht nightshades spray tint, that sounds crazy I know lol but d**n it looks great! I clearcoated it 3 times, polished it up, and waxed it 3 times, and its slick & smooth and looks great. Here are some pics. I also did my door & tailgate emblems with it, and I smoked my taillights and brakelight with it, and it turned out very well! Right now i'm debating weather to do 1 light layer on my headlamps, I dont know if I will or wont, but i'm gonna wait until I have the billet grills to make up my mind.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
