Oil Cooler Adaptor On 5.7l Gmc Sierra
:chevy: Hello people! More fixin going on in the Valley-O-Da-Sun!!
'88 GMC K1500 4x4
5.7L/350ci TBI engine
28" wide radiator with Tranny and Engine Oil Cooler options
The adaptor that bolts to the bottom, drivers side, rear of the block. This adaptor allows the installation of the engine oil cooling lines, that run to the radiator. It also moves the oil filter to a horizontal location.
It leaks between the block and this adaptor as far as I can trace out. I've tightened the two bolts that secure it to the block but it still dripps pretty good. I need the gasket for this adaptor. For some reason I can't find it on auto parts sites. My lame manuals don't even show or talk about it.
Anybody know what this adaptor is "officially" called?
Does it even have a gasket?
Do I have bigger problems?
Thanks for all your help!! :D
I can post a pick if that will help....
Very common with the oil cooler lines leaking....you can get new lines at the dealer but, bend over
:rolleyes: Hello people! More fixin going on in the Valley-O-Da-Sun!!
'88 GMC K1500 4x4
Thanks for all your help!! :crackup:
I have replaced two of these. Remove the oil filter and the bolts holding the adapter on. I did not remove the oil lines. There is an adapter gasket. I have purchased them at the local Parts house by asking for the oil filter adapter gasket. Most small blocks have these between the block and adapter. Be careful and do not use too much gasket sealer. BE SURE all of the old hard gasket is removed or you can break the adapter. HJope this helps.
'88 GMC K1500 4x4
Thanks for the replies!! Here is what I found in case others may need it.
It's offically called an "Oil Filter Adaptor". The kit comes with an o-ring and a gasket.
GM part#: 88893990
other numbers on the package:
7807083
GR.1.840
I had to disconnect the 'front drive shaft' and the 'transmission support bracket' to get enough room to rotate the filter adaptor to remove the old gasket. It was baked on pretty good. The o-ring was flat and hard. Probably from getting to hot once or twice in it's lifetime.
I'm off and running!!! :banghead:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
