Safety Reminder
SnakeEyeSS
it seems to go without saying, but a lot of you know that I'm a car guy, but some things slip past me sometimes. :chevy:
ALWAYS remember to check yourself after working on a car, and wash up. I was on my back with a long sleeve shirt on Thursday morning, just checking some things and detialing the underbody of the camaro.. I had some ATF on the floor earlier in the week and I guess a little was left, and soaked in the shirt on my elbows which were on the concrete for about 30 minutes. It was enough I didn't notice, and I had to run somewhere and really wasn't dirty so I just changed shirt and took off. :D well, now I have a horrid, nasty rash on my just elbows which is a bit odd looking. and engagement pictures tomorrow........whoops :D
That happens wonder why the rash though.
I know my thoughtless thing that I did was when I was changing my fuel filter somehow som fuel dropping into my eye as I was below the vehicle. I felt the pain and felt dumb too! You think that I would learn too whenever under a vehicle, it never fails for something to drop into your eye!
The rash was probably a reaction to the chemicals in the ATF.
I've had rashes before after getting motor oil all over my hands and arms... You know it can't be good for the skin.
Yeah I founfd the MSDS (Material Safety Data Sheet) and moderate skin rash is a side effect to exposeure[if not removed quickly I assume). It's happened before when I did a cooling system flush from heck on the truck and had it(coolant) on me for hours, but that one wasn't this bad
That's weird...I've been covered in every kind of liquid that goes into a vehicle for periods MUCH longer than that...And I've never had a reaction like you describe.
It's not gone but it's going away and MUCH more tolerable. For future reference, cortonzine cream dosen't help too much. some, but it may have been a coincidence but the day after I put Ultra Healing hand lotion on it
Well, you're wierd anyways! :banghead:
Same here...none of that stuff has ever bothered me in the least, and sometimes it will stay on me for hours, if not the majority of the day.
Bah...Kids these days. Allergic to EVERYTHING. :banghead:
They probably don't know the wonderful feeling of the uber-dry skin that results from spending 2 hours elbow-deep in parts solvent without rubber gloves. :banghead:
I personally like it when your skin starts falling off because its so dry. I'm not talking about flaking off, but really falling off. It gives you that tingling feeling...kinda like pain, kinda like pleasure...
Bah...Kids these days. Allergic to EVERYTHING. :ughdance:
If you two go any further I'm gonna..... :banghead:
Don't make me turn the hose on yall! :banghead:
Jeremy, you keep that hose to yourself...I've got a tool that you drop one hose in the solvent bin, and plug the other into the air compressor.
You'll lose the battle of the hoses. :banghead:
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
