I have a 2002 GMC Sierra Z71. I am looking to get a cat-back system soon, probably Magnaflow. What are some of the other bolt-ons that I could do myself? There are cold-air intakes but it doesn't seem like they do much. I could get a tune but shouldn't I do that after the other parts are installed? I'd have to get someone to do that for me anyways. I'm new to the truck scene, i've always had sports cars so I don't know what parts are good and what aren't. Throttle body?
Air Intake combined with a ported throttle body should be a decent combo. Tune's for the most part are mail-order PCM's that replace your factory PCM. Other bolt ons you could do are Electric Fans and headers. You'll want to get the tune last to get the maximum benefit of both the tune and the bolt ons.
yes do the typical NA bolt-ons first, then a good tune with matched injectors. typical Naturally Aspirated bolt-ons like that magnaflow exhaust, a good k&n intake, headers, new plugs, and everything else i didnt mention.
Do headers to much if all I want to do are the basic bolt-ons. I don't plan on adding forced induction or trying to make this a race truck. I just want a little added power. This may be a dumb question but how hard is it to install the Magnaflow cat-back with dual tips out the back? I can follow directions good but I can't weld if need be. Does everything you need come in the box or do I need to order some other parts along with it?
You'll need to weld and torch if your going to remove your factory exhaust and install a new system. The other basic bolt ons are pretty easy and require minimal tools. An aftermarket air intake only requires screw drivers for example. Tuned PCM's can be had for cheap and are the best bang for the buck out there. For a little over $150 you can get a 87/89 or 91/93 octane tune. 87 tunes give 15-20hp, quicker and more firm shifts. 93 tunes do the same except they give in the area of 25-30 hp. It's also very easy to install a PCM, only tools needed is a ratchet wrench and the appropriate sized socket.
Everything you need would be included in your exhaust kit.
I'll just have a shop do it then. One more question. If I have the cat-back installed and a few months down the road I want to go with a set of long tubes can I do that or do I have to do it all at once?
My flowmaster series 40 dual kit took no torch or welding, I had to saw off a bracket - that was it. It looks better welded to get rid of the clamps, that's it. The biggest hp jump I got was from the k&n cold air intake. Other than that, a tuner, or a throttle body spacer.
TB spacers make noise and thats about it, dont buy one. I should have said welding isn't necessary, but I wouldnt do it any other way, then again I went to aerospace welding school :D
I got 11 horsies form the throttle body spacer... During plumbing school, I learned my welds leak like hell (Found out on the last day that I should've been using my left hand) but was waiting for the true dual to clean up the ugly clamps. Hey, how do you like your series 40? Mine seems a little quiet... did they add a resonator under the cab on yours?
Its good, its kind of loud, but Im going to replace it whenever I get around to ordering a Spintech or Borla. I dont have a resonator under the cab. My system is cats, Y, muffler, duals out the rear.
You dont need to weld and torch your exhaust kit if its a cat-back magnaflow. They come with all the necessary hardware including the clamps.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
