Herculiner Kit...questions
I have discovered pitting...eating...destructive rust at the cab corners of my truck...where the old 88-98 trucks would rust out badly.
To save these areas, i would like to run a line of herculiner trim on the lower portion of my truck.
However, i saw a friend of mine do it to his Sonoma, and it looked really s**tty to me...i could see that look on a 4x4...but not a 2wd...it was like rough concrete...and somewhat dull...he used the roller with the kit..the rough surface one.
Here's my questions...
1.) Has anyone put on Herculiner with a finer roller? Like for normal house paint? Im looking for a less abrasive texture.
2.) Has anyone put on the UV Topcoat product from Herculiner? (They say it protects the finish, and makes it shine) ...how did that work out for you?
3.) The area around the cab corner hole (its about the size of a dime) is very very very weak...almost like if i really sanded the s**t out of it, it would give way to an open hole the size of a half dollar...would herculiner act like a strengthening agent for this? Or should i just sand away and let it give way...because it will just rot?
Thank you to all your answers! I sincerely appreciate this!
The herculiner stuff has big granuales so it will probably be real rough no matter what you apply it with. Duplicolor has some new paint protection stuff that will wash off. Durabak http://www.nonslipcoating.com/ also sells bed liner stuff in different colors. The herculiner is supposed to be avavailable in at least one other color too.
If you don't want the rough texture that Herculiner or Durabak, I would go to a auto paint supply store and get some spray-on bedliner stuff, or search Ebay and then spray it on with an undercoating gun. This way you can control the texture and have it turn out fairly smooth or with an orange peel look, and even color match it to your truck.
you could have it rhino lined....they will strip all the paint where they are going to put the liner on and you would be good to go....not sure if you're looking to spend that much, but it would be set for life
for a 6'6" bed on a full size truck and going over the rails i was charged $425...so i wouldnt think just doing the two sides would cost that much..
  • 4 weeks later...
If money is not an issue, I would recommend a professionally applied bedliner. I just had one sprayed yesterday, in fact, and was very impressed. The liner I chose was a Line-x based on recommedations I saw on an earlier post. The product is so strong it can easily make up for weakened metal due to rust. A sample of the product was sprayed on an empty soda can, the product is so rigid that the can would not bend, even under great pressure. I doubt that a hand applied product would have the ability to add enough strength to reinforce weakened metal. At $459.00 it was not cheap, but I truly believe you get what you pay for. I would strongly suggest a professionally applied liner if you can afford it.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
